i just finish the hardware part of my machine and began the trial and error part with resins, exposure, thickness, etc ... Of course, the software used is CW. Nice software.
For a machine ready to print, and perfectly calibrated is perfect, but in trial and error stage, i miss the posibiliy of custom buttons.
Examples: open and close servo shutter M280, read the Z position M114, go to X position, etc ...
i use the manual gcode window, but having the possibility to store the most used actions will be fantastic!
CW and custom buttons!
Re: CW and custom buttons!
You're going to have your wish very soon. I'm in the process of finishing and preparing a 'Pro' version that can do all this and more.
i just see .75 version and have a shutter control. how to configure?? and .... in configure machine, i see a new tab, user parameters. which is intended purpose?
hi, i just tried the new feature and dont work
for example i put M280 P1 S10 and M280 P1 S45 manually and the servo respond opening and closing.
i put the same values in cmdOpenShutter and cmdCloseShutter, but nothing happens. Maybe a syntax error in my side?
anyone has tried and make work the new shutter buttons present in version .75 ?
I use it seems to work fine. Make sure that you add the code and check the box under settings for shutter control
