Laser Cut Panels
				RapturedByRobots
- Joined: Fri Oct 24, 2014 4:41 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Laser Cut Panels
First off, thanks for the work you've put in making a really affordable DLP/SLA printer!  I see that the STLs for printed parts were made available after the KS campaign successfully concluded.  Congrats!  And thanks for releasing the printed parts.  Is there somewhere to get the design files for the laser cut panels?  We have a laser cutter + FFF printer at our Fab Lab and are dying to start a LittleRP build.
				tag1000
- Joined: Sat Nov 22, 2014 1:10 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Laser Cut Panels
Were you ever able to get the cut templates for the panels? Thanks!!
				goopyplastic
They will be releases shortly after batch 1 users receive their printers are are happy with it ... ie no need for changes. If you are jonesing to get to the files early you can stop by #dlp3dprinting on freenode.
				RapturedByRobots
Update on the panel design files?
				mystamo
- Joined: Wed Feb 18, 2015 11:21 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
It's on their site under Technical Support. All in DXF
Regards,
Mo
						Regards,
Mo
				brownmeister
- Joined: Sun Mar 22, 2015 6:27 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I am planning on building a LittleRP printer, but there are a few things that are not specified in the "Packing List" or the "LittleRP Part Source List", i.e. the thickness of the Melamine MDF. I would like to buy the correct thickness MDF to Laser cut.
Does anyone know how thick it is, or could someone measure it on there printer?
				Navstevnik
- Joined: Wed Nov 26, 2014 8:08 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I want to second this can anybody please measure thickness of MDF boards and acrylic glass? Thanks
				lab
- Joined: Sun Mar 08, 2015 1:39 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
The MDF is 6,8mm (1/4") , the Acryl is 2.8mm (1/10").
				shomar
- Joined: Mon Jun 29, 2015 10:30 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi Guys,
any good place to source the light hood acrylic that does international shipping? any help would be great.
				goopyplastic
I originally did my panels through ponoko, I believe they might be international. If you really get stuck PM me and I can cut and ship internationally.
