Hi everyone,
i've been experimenting with some water clear resins, what i've found out is they are extremely hard to print with normal off the shelve projectors.
tweaking my current setup with a custom projector produced these 2 lovely ear buds.
layer thickness = 0.05mm
exposure time = 4.8 sec per layer.
intensity set to 102% on my projector
pull up speed 50
down speed 650
vat - flex vat
Water clear print
how_eee
Re: Water clear print
hi. i also had a try with clear resin.
what tweak of projector you made?
here is my best result. same resin with and without pigment. layer time 400ms and 300ms.
with less time print will be broken
what tweak of projector did you make?
how_eee
Was it printed with your acer?
Mine was printed with acer p1500 with ptfe flex vat.
this one wasn't.. i have similar prints though.. printed with my acer p1500
layer height should be set to 0.05mm though.. per layer..
jkao
- Joined: Sun Jan 04, 2015 5:42 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Was this the Venus Creator water clear? (If so, was it the standard or B9Creator formulation?) Or some other brand of water clear?
Hi jkao,
its the b9 water clear from venus creator.
