I have had better luck with 3-5mm wall thickness.   Whenever I can possibly get away with it I use 3mm solid supports. I do NOT like the part separating from the support.
The printer is just a custom build top down unit.
In the past I had used netfabb to hollow the part but that costs money...now that Meshmixer does it I think it is the best choice.  I also like Meshmixer support generation.
						More @ 100 microns
				kakapoopie
Re: More @ 100 microns
Thanks for the info...I just started using meshmixer and the supports are great...especially that they branch out, seems a bit stronger.
