My Printer in Actione - inc Flexvat
- Joined: Sat Jun 28, 2014 4:57 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: My Printer in Actione - inc Flexvat
Where did you buy the FEP film?
on alibaba,
type in conveyor belt fep film - and try to get 0.05mm thick film(300mm wide).
$50 for 0.5KG of film, which lots and lots of meters.
Kind regards,
Edwyn
Kind regards,
Edwyn
- Joined: Wed May 14, 2014 10:40 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I have 0.1mm Fep film here but its not so optically clear as 0.05mm
it is still on my todo list, but i think 0.1mm is much harder to stretch on my cheap container vats then 0.05mm
so i will stick with 0.05mm and even try 0.03mm.
Kind regards,
Kind regards,
That looks amazing Edwyn!
Same quality like the purple one you have printed I guess?
Hoi Koos,
similar to that other one, but a little bigger
i'm trying some other resins now.. water clear.. can't wait to show some results
cheers
cheers
