RC3 - first image shows automatically at end of slicing
gmoneyphx
After slicing completes the first image appears (most unwanted) automatically...leading to panicked search for "show blank" button. Using projector on \\display2 in this case.
Re: RC3 - first image shows automatically at end of slicing
There is a checkbox on the view slice display called 'preview'. If you leave this unchecked, the image will not be displayed on the secondary monitor.
gmoneyphx
Seems that this should be checked=false by default. If you forget to manually uncheck it you get blasted.
