Hi guys, I have an Acer H6510BD projector that I'm trying to turn on/off using CW. I have an RS232 to USB cable, baud rate at 9600 and # of bits at 8
It says "Display driver not connected" when I try to send commands and nothing happens.
Hex code should be 10C8E11E to turn on according to the manual. Does anyone have tips on how to get this working?
Vaughan
Controlling projector
kakapoopie
Re: Controlling projector
What version of CW are you using? It sounds like you're setting everything up correctly. You need to make sure that you're using a null modem gender changer with the projector. If it's saying 'display driver not connected', be sure that you've clicked 'Apply' after making changes. It sounds like the port isn't being opened. The serial port for the display gets opened right after the main Arduino port is opened.
kakapoopie
I'm using the latest v .29
I'm hitting apply. The arduino port is com6
projector port is only showing com6 for some reason(tried hitting refresh, restarting cw, unplugging and plugging back). I've tried different USB spots, even swapping the projector to where the arduino used to be and still no luck.
Here's the USB to RS232 I got
