Can anyone tell me which resin is going well for brass casting, my method is by direct casting.
- 1 printing 3D model;
- 2 3D model goes for brass casting;
- 3 model ready made injection molding in wax, for there yes production;
My greatest difficulty lies in the casting of these resin parts.
Use MakerJuice Wax Cast - does not work
B9 Emerald - Works me parts ...., but hardcopy compared to MakerJuice
Resin for direct casting.
Re: Resin for direct casting.
Research Chemist
provin
- Joined: Thu Apr 20, 2017 3:31 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
[img][IMG]http://i65.tinypic.com/dmqogn.jpg[/img][/img]
hirenashra
Looks to me like you have not executed the burnout process properly here?
Did your original prints come out properly?
Nitros
i hade the same issue with wax cast, what's the best procedure of burn out, and even i have issue to attach the spung?
provin
How my impressions came out perfect. But a cast left me with no ground.
provin
What would be the best way to do the casting process.
Which investment is best for MakerJuice?
The post-cure system?
system post-cure!
system post-cure!
