A8creator :)
Re: A8creator :)
It was FunToDo std red
Re: A8creator :)
Very nice!
So any problems with wobbling? I plan on using lm10uu on my build.
- Joined: Mon Jan 19, 2015 7:55 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: A8creator :)
Would you mind sharing your files? I'd love to laser cut my own parts and try out this design.
- Joined: Sun Jun 14, 2015 2:40 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: A8creator :)
how_eee, what firmware use in your printer?
- Joined: Sun Aug 23, 2015 6:56 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: A8creator :)
Have the files for this printer been shared anywhere?
Re: A8creator :)
I almost forgot about this topic
Here 2 versions - slide and flexible vat
https://www.dropbox.com/s/u5iy2ch2iu73j ... LDASM?dl=0
https://www.dropbox.com/s/whkdcqevxbbyl ... LDASM?dl=0
