				malamen
- Joined: Sun Feb 12, 2017 10:21 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I will try to write more thoroughly.I have disassembled the step motor...But there is no problem with it.i thought the rod spins in the anchor,but is ok...I tried to find resistor to make more voltage to the step motor,but I could not find it...There were not tightened screws that hold nut .. Maybe it was the problem.But I have noticed it is very difficult for the motor to lift the platform any way.What if I increase the gap between bottom of Vat and platform....
				LacoDeLoco
				Dr. Woo
- Joined: Mon Aug 31, 2015 5:39 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Uhm... Honestly, what do you expect for a printer which is less than USD 700 incl. shipping?
This printer is by far the cheapest off-the-shelf resin printer money can currently buy. If you want service, a proper manual and customer support, you should have gone for a Formlabs form 2 or SprintRay MoonRay S, but with price tags of USD 3,500+, those do cost more than 5 times as the Proniks.
Welcome to reality! And believe me: even with a Formlabs or MoonRay, there’s a learning curve on what works and what doesn’t. Resin printing is tricky and a game of trial & error.
				malamen
I have found the problem.It is a display card.It doesn't work constantly.If I touch HDMI cable it works...I will try to repair it.And I have found the resistor to risen the voltage to the step motor.I have made DIY printer before-fdm .It works.So, I can see this printer is not so complicated.But it is not robust.I would like to make some amendments to mechanical part.... But I need to repair this damn display card..
				malamen
And I think we should place here some links to the new owners.Soft, videos about workshop etc.
				Janowan
- Joined: Wed Mar 22, 2017 1:28 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hey guys!
I just got my printer today and it's blue! Oh well, looks kinda nice.
But: I noticed there is no glass to attach to the platform. I contacted the seller and he said - Quote: "We do not sell glass anymore. It has been improved." And his answer to my follow-up question: "How can I level it then?" was: "Because do not need leveling anymore."
Just a visual inspection shows that the platform cannot possibly be leveled as is. Now what? ^^
He is going to send me the manual tomorrow, i got the raspberry pi version and i would like to make sure to do everything the right way and not meddle with it beforehand.
Cheers,
Jan
Cheers,
Jan
				Dr. Woo
Uhm... What has the glass on the build plate to do with the leveling? AFAIK the build plate can be manually leveled using the 4 screws surrounding the black mounting knob. It’s described in  at 5:00.
				Janowan
Dr. Woo, oops yeah you're absolutely right - for some reason i thought the leveling was done by the glass on the build plate much like a heated bed on an fdm-machine. But still, does it make sense not to have the glass? Does anyone of you have a link to the manual with the raspberry pi version so i could get started today? The link in one of the first posts is dead.
				Janowan
Nevermind, everything is explained in the video. Sorry for dumb-spamming.
