I just got the printer. Made a dry run, working fine. But:
I got the version with Raspberry Pi. I see the wifi address (192.168.0.100:9091). But Im not able to connect to it. No from PC, no from iPAD, no from Android tablet.
Getting error code: Connection Refused
I need to work with cable connection (RJ45, ).(192.168,0,107:9091). Thats working.
How to connect to the printer via Wifi?
Thanks.
Laco
- Joined: Tue Jan 17, 2017 10:45 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Dear colleagues!
I bought a printer and I can not get it to work. After all the action according to the instructions on the printer no response. I had to buy a new computer, so that it meets the required resolution graphics card.
Already twice I did a full permutation of drivers and programs, and any result. Inside the device non visible damage.
Manufacturer James Louis, nothing concrete answer me and could not. And now he has a vacation may be someone who can help, how to revive the printer.
- Joined: Sun Dec 04, 2016 5:48 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hey
It's really hard to help you since you do not tell us what isn't working?
I presume you're not using the raspberry pi version?
Can't control the movement?
Don't get a picture on screen?
What software do you use?
Did you install the serial driver ?
Running Windows or OS X ?
Where do you get stuck in other words
Best,
//O.
Best,
//O.
the first connection is exactly be with RJ45,
then clik on "nanodlp" logo in the upper left,
from here clik wifi at the top right, enter the wifi network configuration page
- Joined: Thu Jan 19, 2017 9:17 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi
tell a minimum layer thickness XY and Z
No Raspberry
No light, no movement
Nothing on the screen
Windows 7, Creation_Workshop_54
driver from wch.ch CH341S64 ver. 3.4.2014.8
Yes Windows
No reaction from printer. One time a ltlle moving up-down, but not possible operate from programm app. go Zero. Realy nothing
No Raspberry
Yes Windows
I had the same problem...but no movement at all.
I gave up running it on windows and instead bought a raspberry pi 3...and installed nanodlp...
..now doing that is not for the faint hearted
I posted earlier on this thread the steps to make it work...basically you download nanodlp, install it onto a microsd card, figure out how to talk to it via a terminal window...setup the special settings for the resolution to work...then configure nanodlp from scratch.
I hope that is of any help...should really make a proper tutorial but just got too much on at the moment.
Best,
//O.
[squote="jindra750"]I presume you're not using the raspberry pi version?
No Raspberry
Yes Windows
No reaction from printer. One time a ltlle moving up-down, but not possible operate from programm app. go Zero. Realy nothing[/quote]
Best,
//O.
No Raspberry
Yes Windows
