My first prints with littlerp.
XYZed
- Joined: Fri Sep 23, 2016 7:26 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
First of all a big thanks to all you guys for sharing all those informations and making it possible to build such machines.i am using a modified acer x152h with flex vat.My first print was a calibration grid that came a little oval but then i got it right and printed a ring.
Nitros
Re: My first prints with littlerp.
well done, what resin you use?
XYZed
Funtodo resin.
Nitros
With flex vat or PDMS?
XYZed
I am using a flex vat.
Head-Zonk Studios
- Joined: Tue May 24, 2016 6:14 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
radi2k
- Joined: Mon Sep 28, 2015 8:22 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi Head-Zonk Studios,
for me it helped to increase the exposure time and increase the FEP tension!
Greetings,
radi2k
Greetings,
radi2k
goopyplastic
head-zonk, it is worth noting that the htl flexvat has a much lower tension than the seeme vat you are using, so when he says increase the tension take it with a grain of salt. After some additional testing it looks like the lrp2 will be using an integrated htl style vat with an acrylic underplate, this lets you run the film on the loose side for better peeling but won't result in sagging. If you want to email me I can get a set of parts if you want to go this route.
the see-me-cnc vat does work and will still be compatible but the high tension was causing intermittent layer lines in prints.
Head-Zonk Studios
