Thank you guys.
How many ours do you cure the rings under the UV light. What wattage of UV do you use ?
Can you also post a picture of the all the way cured model to see the color
thank you
						Resins For Investment Casting
Re: Resins For Investment Casting
Research Chemist
				jimmyjackson
- Joined: Thu Jul 28, 2016 7:55 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
				cerriousdesign
I cure my resin with heat, an old heating element, at 200 degrees in a vacuum chamber for 2 hours.  Cures the resin all the way through not just on the surface like U.V. does.
Interesting.  I don't see why the vacuum is needed though.  Can you explain this aspect?
				chill74
- Joined: Tue Jun 16, 2015 3:09 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Test Bracelet Links
WaxCast
R&R Ultravest...
No problems casting WaxCast and these are on the thick side for testing.
						WaxCast
R&R Ultravest...
				svs
from the biggest jewellery casting factory of europe & asia...
