As I'm planning on making the machine as compact as I possibly can (which is quite hard with a normal beamer) I prefer if I can get a good quality (high resolution) Pico Projector to do the job for me. I saw by Rich showing how he modified his LCoS LED pico projector to send out UV light instead of normal light. I might go that route in trying to find a LCoS pico projector, but usually they are SD projectors.
I saw (bit more expensive) Sony MP-CLI1 Laser Pico Projector, but I'm uncertain if the laser can be adjusted so that it emits UV light (current wavelength is 445 nm to 639 nm). I wonder of any of you have experience with adjusting any laser pico projectors, maybe even know how the insight of this Sony MP-CL1 looks. With a resolution of 1920x720 and a 40" projection size at 1.15m distance, it seems like a good option to print medium sized objects.
Any thoughts and comments are more than welcome! Hopefully I will be able to post in the 'Show your SLA' section soon
