Basically I have tired all settings I can think of including moving back the P1500. Print ended up being smaller and and moved to the edge of the bp.
I am unable to get deep red Makerjuice only white with added red pigment however I had the same deformation results with made solid V2 red.
focus is fine, at least it seems on test image projected on ceiling in mirror mode. The model gets built in right place on build plate except for the poor print. Base Layer size and shape seems most close to what it should be.
Played with all settings for exposure but it seems that the problem is coming from some other setting issue.
I think the only logical problem is with the setting of the P1500 itself except not sure what to change.
I also adjusted output on projector to bright.
