Creation Workshop version 1.0.0.54
CAP257RM
- Location: Roma (Italy) [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Creation Workshop version 1.0.0.54
I have tried some others testings and now the lift function well, but if I see the GCode View all the slices have the same values from the first until the last. I believe that it is a problem because if I need to find where is a mistake in this situation is impossible. The other thing that I don't understand it is how to come back to the zero position with the platform when the work is finished. I have tried to modify the session of the GCode how showed in the screenshot, but the lift remains in the last position of the slicing.
Leinad78
Is there a newer version then 1.0.0.54 available? I´m still having the problem that the connection between the dlp projector and my win 7 pc gets lost after one or two prints and the pc needs to be restarted for getting the connection back to work. Its a bit complicated and annoying.
nc42
https://dl.dropboxusercontent.com/u/537 ... 0.0.75.zip
Projector issues might be more computer related. On one of my computers getting it to connect to the projector is a nightmare but on the little 7" windows tablet I got as a dedicated machine it works great
You'll need to install the latest .NET components for XP.
nalmeida
I will try it tomorrow. Thanks a lot Steve.
Leinad78
i still think that its a bug in the software as even the Ramps doesn´t drive the stepper.
nalmeida
The same is happening to me, I updated .net until the most recent version supported by this OS (4.0.3) and CW won't run. I suspect that it might work with newer versions of .net (like 4.5 and up) but we can't install these ones on XP.
