B9Creator Firmware
pouryatorabi
- Joined: Sat Feb 14, 2015 1:00 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
B9Creator Firmware
Can anyone help me with B9Creator firmware? This firmware is so nice it can control every thing easily but it's too complicated. I was working to make my own DLP printer. At first I used B9creator software and firmware and so the Sliding method. I wasn't familiar with other methods. I had some problem with PDMS so I really wanted to use FEP but as you know you can't use FEP with Sliding so I wanted to make my own printer with tilt. My problem is The B9 uses a DC motor with encoder to do the sliding. I wanted to replace it with a stepper to use the tilting. I've read the B9 firmware many times but I can't figure it out. Can anyone help me? I really need some help.
Re: B9Creator Firmware
Hi; Pouryatorabi.
Below is a link for your request. Take the chance out of choosing; The simplicity is in "The CW".
Best Regards
Saeed
▶ B9 Creator SLA DLP 3d Printer - YouTube
https://www.youtube.com/watch?v=XK_m9FU_4OE
Best Regards
Saeed
pouryatorabi
Hi, Thank y ou but I didn't find anything useful in that link. I wanted to modify the firmware to use tilt not slide
Hello Pouryatorabi;
Here is just an another link, to Youtube. The CW is a great printing software and it is getting better and better; and its friendly community is growing.
Delightful Regards
Saeed
https://www.youtube.com/watch?v=eWyMT6KpVeg
Delightful Regards
Saeed
pouryatorabi
Hi
Thank you very much but I've seen this before. I need to replace the dc motor with a stepper one.
Again thank you for your reply.
Xoxu
- Joined: Sat Jun 13, 2015 1:55 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
A long time ago I went to make the same, use the b9creator code with a stepper motor, the firmware is a little to complex and to big, it's a big job and you need serious knowledge in programing arduino or microcontroller to modified this.
Maybe you can found more information in the b9creator forum...
Xoxu
Xoxu
Hello Dear Readers;
Your time is valued and appreciated, it is about the B9 application. Just for my knowledge I have been keen to play with the B9 software. I acquired all the necessary components, the assembly is very straightforward. I have tried to run the software on MAC and PC, system. For some reasons the Active Printer Port None Found.
Please find attached snap shots, I have tried many possibilities to come over the Glitch, as-well I have all the back-up components. At B9 forum. I came across one video link, pointing out that it is a driver issue. Your kind input is much respected.
Best Regards
Saeed
https://www.b9c.com/support/documentati ... r-settings
Best Regards
Saeed
