B9Creator Firmware
pouryatorabi
B9Creator Firmware
Postby pouryatorabi » Sun Jul 12, 2015 8:59 am
Can anyone help me with B9Creator firmware? This firmware is so nice it can control every thing easily but it's too complicated. I was working to make my own DLP printer. At first I used B9creator software and firmware and so the Sliding method. I wasn't familiar with other methods. I had some problem with PDMS so I really wanted to use FEP but as you know you can't use FEP with Sliding so I wanted to make my own printer with tilt. My problem is The B9 uses a DC motor with encoder to do the sliding. I wanted to replace it with a stepper to use the tilting. I've read the B9 firmware many times but I can't figure it out. Can anyone help me? I really need some help.
Re: B9Creator Firmware
Postby SIDRANA » Sun Jul 12, 2015 10:43 am
Hi; Pouryatorabi.
Below is a link for your request. Take the chance out of choosing; The simplicity is in "The CW".
Best Regards
Saeed
▶ B9 Creator SLA DLP 3d Printer - YouTube
https://www.youtube.com/watch?v=XK_m9FU_4OE
pouryatorabi
Postby pouryatorabi » Sun Jul 12, 2015 8:07 pm
Hi, Thank y ou but I didn't find anything useful in that link. I wanted to modify the firmware to use tilt not slide
Postby SIDRANA » Mon Jul 13, 2015 12:32 am
Hello Pouryatorabi;
Here is just an another link, to Youtube. The CW is a great printing software and it is getting better and better; and its friendly community is growing.
Delightful Regards
Saeed
https://www.youtube.com/watch?v=eWyMT6KpVeg
pouryatorabi
Postby pouryatorabi » Mon Jul 13, 2015 6:56 am
Hi
Thank you very much but I've seen this before. I need to replace the dc motor with a stepper one.
Again thank you for your reply.
Xoxu
Postby Xoxu » Mon Jul 13, 2015 12:24 pm
A long time ago I went to make the same, use the b9creator code with a stepper motor, the firmware is a little to complex and to big, it's a big job and you need serious knowledge in programing arduino or microcontroller to modified this.
Maybe you can found more information in the b9creator forum...
Xoxu
Postby SIDRANA » Fri Aug 14, 2015 11:44 pm
Hello Dear Readers;
Your time is valued and appreciated, it is about the B9 application. Just for my knowledge I have been keen to play with the B9 software. I acquired all the necessary components, the assembly is very straightforward. I have tried to run the software on MAC and PC, system. For some reasons the Active Printer Port None Found.
Please find attached snap shots, I have tried many possibilities to come over the Glitch, as-well I have all the back-up components. At B9 forum. I came across one video link, pointing out that it is a driver issue. Your kind input is much respected.
Best Regards
Saeed
https://www.b9c.com/support/documentati ... r-settings
