hi all new to the group ...
ive been following this group for a while now and in that time ive been building a dlp 3d printer my problem is
no matter how much I read I cant get the light bulb in my head to turn on when it comes to setting up marlin or sprinter. and how to get the z axis going... im looking for some one to help me under stand this .... please help  here's my email if needed hiddenlayersairbrushing@gmail.com mabey some can one on one guide me on this Thanks...
im very good at the design stage but not the codes YET
						fimeware z axis all of it? help ?
				transformer
- Joined: Sat Jun 06, 2015 11:17 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
				sodium
Re: fimeware z axis all of it? help ?
https://www.dropbox.com/s/xc06nixf2xkpg ... 1.zip?dl=0
this is my working marlin firmware. if Z motor not working with this firm, you should check electronic side, ramps, cabling, power supply, etc ...
				transformer
thank you is it ok to have two endstops max height and min?
				transformer
every time I try to upload marlin to the board it just hangs for ever.. lost sorry
				newraper1963
- Joined: Mon Jan 19, 2015 6:55 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
try sprinter. that's what I use. Everything runs smooth.
