Blue Slices
mcguinnessdr
- Joined: Mon Jan 05, 2015 5:32 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Blue Slices
In the newest version of Creation Workshop, the slices are blue, instead of the white they were before. I have removed the color wheel from my projector, so what color the slice is doesn't affect the color of the projection, but it does affect the intensity. The slices are now much dimmer, so I am hoping there is a way to change the color back to white, or I'll just have to go back to using the older versions. Thanks for any help!
mcguinnessdr
Re: Blue Slices
Perfect, thank you! So the default was just changed from white to blue in the newest version?
