weird surface finish - flakes every where
Posted: Tue Oct 06, 2015 1:34 pm
				I’m having troubles with flakes appearing after few layers on my prints.
On first place I thougt was a optical problem so I perfectly cleaned the galvo mirros and the 45° one.
Recalibrated galvos and laser (build extends, laser extends and dot layout).
Tested again with same results.
An odd fact is that the firsts layer comes very fine.
All resins used for the test were from new bottles and well mixed before print.
The printer was turned off for about 1.5-2 months.
When opened retina software I performed the last upgrade. Also I noticed that there is a galvo test, how this test should be performed?
Attached is a pdf with example images.
Any help or work around will be appreciated I have a print order that I need to deliver ASAP.
