Page 3 of 5
Posted: Thu Aug 21, 2014 1:13 am
by Craig Turley
Set Three
Posted: Thu Aug 21, 2014 6:15 pm
by MichaelD33
Posted: Mon Aug 25, 2014 6:09 am
by Craig Turley
@MichaelD33 - I'm currently using the b9Creator.
Posted: Mon Aug 25, 2014 11:36 am
by adambx
@craig:
the prints are awesome!
I think the B9s sliding VAT has a lot to do with the print quality. I'm pretty convinced by the FTD resin though, looking forward to the castable blend, haven't tried it yet.
could you post a picture of the bottom surface where the small supports attach to the horn like structure (next to the coin)? . I believe I need to alter my vat mechanism a bit.
Posted: Wed Aug 27, 2014 1:42 am
by Craig Turley
@adambx - Thanks man! Plans to test out a tilt pretty soon, I'm very interested to see how the two release mechanisms differ. Post some pictures
I'll get that picture tomorrow.
Posted: Fri Aug 29, 2014 1:03 pm
by Magnitude
Is this the regular or high strength stuff. Anyone have experience with the industrial blend?
Posted: Fri Aug 29, 2014 3:20 pm
by Craig Turley
@magnitude - the red images on the second page are the standard blend, the green is the industrial blend, pretty much all I print with now.
Posted: Fri Aug 29, 2014 11:57 pm
by Magnitude
@craig is it that much stronger? Do you still fear dropping and shattering builds?
Posted: Sat Aug 30, 2014 9:47 pm
by Craig Turley
@magnitude - yes the Industrial Blend is quite a bit stronger than the Standard Blend - which is still a great low cost solution. I'm not worried about dropping pieces within reason, they don't shatter.
Posted: Sun Aug 31, 2014 6:13 am
by seblos
Hello Craig,
You castable resin photo?
What times and resolutions to use on your b9?
thank you
