Build Your Own SLA/SLS • Daylight (iPad) Printer
Page 1 of 2
Posted: Thu Mar 24, 2016 5:36 pm
by Kvirre
This becomes my second printer, this time using the Daylight resin.
Some links :
My first SLA project :
This project (buildlog) :
Previous thread for testing :
Here is the concept and what I got ready so far.
Re: Daylight (iPad) Printer
Posted: Fri Mar 25, 2016 4:30 pm
by AndersonTa
Any reason you have the base so tall? Are you planning to put an LED array under it?
Posted: Tue Mar 29, 2016 3:54 am
by Kvirre
Posted: Fri Apr 08, 2016 2:56 am
by marcovanschagen
Can lcd panels be used as backlight?
http://m.ebay.com/itm/272000555196
Posted: Fri Apr 08, 2016 7:41 am
by Kvirre
Posted: Sat Apr 09, 2016 11:15 am
by educa
Why not use a high power UV led and a fressnel lens to get the (nearly)pointlight of the led into parallel rays of light ?
Posted: Sun Apr 10, 2016 11:09 am
by dpizzle
educa, This has been discussed in the past in another thread. A fresnel lens might work for daylight resins (not sure anyone has tried), it most likely won't work for UV. Since a normal color LCD blocks so much in the UV spectrum you really need the low degree collimating lenses right under the panel to blast enough light through the panel.
Posted: Thu Apr 14, 2016 3:10 pm
by Kvirre
Now, things are coming along.
Did FW and Electronics this week.
- Added two code-commands to Marlin FW (1 to control text in a smal OLED display and 1 to Control iPad Display back lightning).
- Not to easy the last part, since hardware Serial not possible. Software Serial is however.
- Added a 12V->5V transformer for powering the Abusemark Display driver.
- Soldered all wires for the serial communication interface, and figured things out in general.
Next is Routing out the plate for the VAT, and the VAT itself (design change here).
To be continued.
Posted: Thu Apr 14, 2016 6:20 pm
by Redrichie
Man can't wait to see it. Have you done any tests using a z axis to actually pull out a part? The last I saw was a bit of promising exposed lettering.
Posted: Thu Apr 21, 2016 7:19 am
by Kvirre
I have now ordered the last parts that I need to do my first print.
- Build Platform
- VAT
- Top Frame Plate
- Enclosure
ETA 2 Weeks + Buildtime
