Build Your Own SLA/SLS • Nema 17 slipping
Nema 17 slipping
Posted: Tue Jul 29, 2014 4:09 am
by 999dom999
I'm using a RAMPS controller and a NEMA 17 motor.
When its connected to the z-axis spindle and I try to move it 1mm it just slips and vibrates.
Without it connected to my Z axis spindle and I hold it with my fingers and move 1mm, it turns fine both directions. If I apply a small amount of pressure with my fingers then it slips.
Any ideas why this appears to have such little power?
Re: Nema 17 slipping
Posted: Tue Jul 29, 2014 10:09 am
by Finhead
What are your stepper motor specs? Have you adjusted your stepper driver properly?
Posted: Tue Jul 29, 2014 10:38 am
by 999dom999
I'm starting to get somewhere. I adjusted the pot on the stepper driver and it increased the power. I also noticed the spindle was a little tight when the top plate was tightened and also when the linear block is screwed into the spindle. I loosened these and it worked fine. I will try to add some washers to adjust the height and the distance of the blockl and tighten to see if this allows it to move freely.
Posted: Tue Jul 29, 2014 10:41 am
by adambx
maybe the motor current of your microstepping driver is just way too low. Check with the motor data sheet and adjust accordingly.
Posted: Sat Nov 08, 2014 9:16 am
by cncbasher
stepper motors slipping or not moving or irratic etc , is mostly down to either trying to run the stepper at a higher speed than it's capable of
this can manifest it's self in many ways .
such as low voltage , not enough current , incorrect setup between what you have the stepper driver set for and the actual step pulses
i.e setting the software for for say 1/8 step and having the actual hardware set for 16 microsteps .
ideally for steppers you want the highest voltage for the stepper driver spec and around 3A for each stepper your using
most stepper drivers can accept upwards of 24v , and with the advent of modern stepper drivers they take care of the current rating
put very simply voltage gives you speed , amps gives you holding torque for the position .
however there is a trade off the higher the microstepping the lower the torque available ,to overcome z axis forces of gravity etc
this will show it's self as slipping downwards , especially if a fast move or high acceleration
if ever your faced with a stepper that seems to slip , modify your step rate and acceleration , by reducing by 50 % and try again
once you have it working correctly then you can bring the speed up in stages
hope this helps people understand steppers a little bit more
