Page 1 of 6
nanoDLP - Raspberry Pi DLP Host Software
Posted: Fri Aug 21, 2015 12:08 pm
by shahin
Hi all,
After my previous post about Raspberry Pi based DLP printer host software quite few people asked for demo version.
I have prepared a demo version which could be installed on RPi 2.
You can download it through following link
For more information about the software you can check out following web page
If you have any problem with the software let me know.
My previous post
Posted: Sun Aug 23, 2015 2:22 am
by Max
Hi shahin,
i see you've released your demo, can you tell me more about the electronics? Can we use the A4988 stepper drivers? What pins should we exactly connect? I'm really noob with raspberry pi.
Posted: Sun Aug 23, 2015 2:52 am
by shahin
Posted: Sun Aug 23, 2015 8:49 am
by jkao
Nice! Do you have a way of setting lift speed and height between layers similar to the layer-by-layer specs in ProjectLayer?
Posted: Sun Aug 23, 2015 12:11 pm
by sodium
wow! its seems very configurable and complete.
then, if you have not yet implemented the grayscale mask, how to use the entire build plate, specially with the acer 6510 ?
Posted: Sun Aug 23, 2015 2:44 pm
by shahin
Posted: Sun Aug 23, 2015 3:04 pm
by shahin
Posted: Sun Aug 23, 2015 6:28 pm
by jkao
With the Kudo3D Titan 1 printer (that uses a modified version of ProjectLayer), I generally use 4-5 regions currently, generally for:
Attachment layer, just 1 or 2 layers at the beginning for attaching the print to the build plate, usually extremely long cure like 60-120 seconds
Support/Foundation Layer - Area at the base of a print or before the part starts that need to be built harder than normal, but not as long as the attachment layer
Transition layer - Something in-between the support/foundation settings and the normal build speed to reduce artifacts from sudden layer changes
Rest-of-print - Normal (faster settings)
Optional - Some of my parts are hollowed and have a roof that comes in later in the print, so I add in another region where that occurs to slow down and increase the lift due to the increased surface area.
There are a few Titan 1 users who regularly use ProjectLayer to change settings in the middle of a print. In particular, they may find that a given lift height is too big or too small after a few sample layers are printed, an then change it.
Based on popular request, Kudo3D made changes to Projectlayer to support 8 regions (I think the original only supported 4). While I have never personally used all 8, there have been a few users who have asked for more than 8 regions based on changing part surface areas in the prints they are making.
In the longer term, I think a better approach would be for a program to analyze the surface area and density of each region, and then based on some base exposure/lift height/lift speed settings, apply a multiplier based on the surface area and density.
Posted: Sun Aug 23, 2015 6:32 pm
by jkao
Also, for wiring a stepper, I presume that you need a separate power supply to drive the stepper? Do you have an example of the full set of components and wiring that you use for your setup?
Posted: Mon Aug 24, 2015 3:23 am
by shahin
