need some help for gcode programming
Posted: Thu Jun 05, 2014 8:46 am
Hello everybody,
I just made a top down DLP printer but it needs some tweaks.
I use a wiper to flatten the resin surface after the Z movement but now it's going in the 2 directions before each slide.
What I want to do is :
- project slice 1
- go Z -0.05mm
- go X -250mm
- project slice 2
- go Z -0.05mm
- go X 250mm
then slide 3 with X negative direction, slide 4 with X positive direction, etc.....
Is there any way I can program that in Creation Workshop?
Thanks in advance,
Jeoffrey
- project slice 1
- go Z -0.05mm
- go X -250mm
- project slice 2
- go Z -0.05mm
- go X 250mm
Thanks in advance,
Jeoffrey
