Build Your Own SLA/SLS • Ilieos UV LED projector mod.
Posted: Sat Sep 02, 2017 4:23 pm
by hirenashra
Has anyome made a huge mod to their LRP with their projector with something like this?
http://www.ilios3d.com/en/shop/shop-3d- ... tor-detail
How could you utilise or postition such a projector? Could it evolve the printer?
Goopyplastic, your thoughts.
Re: Ilieos UV LED projector mod.
Posted: Sat Sep 02, 2017 8:38 pm
by goopyplastic
It's something I've thought about. There is no reason it wouldn't work, and work well, the problem is that I'm not sure there are that many people who want to get into SLA cheap with a LIttleRP, but are ok spending $1500 on a uv dlp :)
I had plans to release a version of the LittleRP that used the projet / miicraft uv micro dlp as you can buy that unit for $600 or so, and even have placeholders on the LittleRP2 controller pcb for the power and control for this projector, however I didn't think the demand would be there and didn't pursue it. I still have one of these units if someone was interested.
The original intent of the LittleRP was to provide a generic platform so that people could buy used dlp projectors for cheap, making total cost fairly low. The only reason I really added support for costlier 1080p projectors was due to demand for it.
Posted: Sun Sep 03, 2017 5:46 am
by hirenashra
Posted: Wed Sep 06, 2017 9:30 am
by hirenashra
Hi Brad,
Any update? Very interested to see some sample prints. If you have any complex rings designs etc, be very much appreciated.
Do you also lose the mirror on the printer?
Posted: Fri Sep 08, 2017 2:59 pm
by goopyplastic
I never actually printed with the setup, however it should be functionally identical to a miicraft or projet 1200.
You can see a short video showing led control with the lrp2 controller.
https://youtu.be/MRyrRtAZMnE
Posted: Sat Sep 09, 2017 11:05 am
by hirenashra
Let's say I was to use the Ileos mini dlp. Is there a chance it might not be compatible to the LRP controller? I see in the video you're bouncing it off a mirror. Can you go mirrorless given the size of these mini UV's? How do you even start to position the projector? A complete base rebuild?
