Page 8 of 9
Re: LittleRP2 Information
Posted: Thu Jun 08, 2017 10:12 am
by cooly
I totally understand. Since LittleRPs are open source and open design, users may change the firmware if they want and are willing to. I can't quite optimize the MonoWare to work with LittleRPs, but hope your users may try and report issues and comments.
Posted: Sun Jul 02, 2017 10:49 am
by Wedd
If we want to upgrade the stepper driver to tmc2100 for littlerp 1, what are the procedures may I ask ?
I read some information about cfg1 2 3 being omitted and connect ground and even cfg1 For spread cycle instead of stealth chop not sure if it applies to this situation.
Posted: Mon Jul 03, 2017 6:37 pm
by goopyplastic
Posted: Wed Jul 12, 2017 4:26 pm
by inframan
Any news on a BOM ?
Posted: Thu Jul 13, 2017 11:54 am
by goopyplastic
Posted: Wed Jul 26, 2017 3:39 am
by alstone
Greetings Goopyplastic,
I am from South africa and I would like to build a Littlerp2. Are you able to provide an 3d part assembly drawing (solidworks, rhino, spaceclaim or other) of the machine for those of us that may need to redesign to suit the parts or fabrication methods we have available to us. I have access to a sheet metal workshop and could more easily manufacture the body of the machine in 2mm aluminium. (Also we are metric). I also would like the projector inline and below the vat. If I can get 3d assembly drawing to work from it would make this more possible. I am more than willing to provide you with the design once completed so that you can see if you want to include it for others.
I tried to contact you via your email message thing at bigcartel.com but I don't think it's going through.
Alstone
Posted: Sun Jul 30, 2017 6:17 pm
by goopyplastic
Posted: Wed Aug 02, 2017 5:12 pm
by Yianni-VJ
I m just starting to use the EBA kit.
There are three pairs of spacers for the acrylic window and sets of washers for the knob screws that hold the VAT down.
I am guessing you are supposed to use tall spacers for the VAT with the clear washers, to create the necessary tension.
Correct so far?
What are the criteria to decide which spacers to use?
What are the benefits/drawbacks of high tension vs the benefit/drawbacks of moderate or tension?
Posted: Wed Aug 02, 2017 7:12 pm
by goopyplastic
I include the extra spacers 'in case' , however generally you would only use the clear discs under the thumbscrews, and the orange spacers under the vat window. By using different combinations of spacers you can tension the vat differently if needed.
Posted: Sun Aug 06, 2017 4:12 pm
by alstone
