Build Your Own SLA/SLS • (Solved) Z arm not moving?? Help... anyone here?
Posted: Mon Apr 06, 2015 10:30 pm
by cerriousdesign
I am not sure what is going on? I am trying to print the calibration .stl. I hit show blank, It says everything is ready to go, I hit play.. the timer is going.. but only 1.44 % is done with 5 minutes into the supposed print. The Z arm is going no where the projector is not doing anything. What in the world am I doing wrong. I am connected with the icon where I can go back and forth showing Little RP are talking and I have done everything in the videos right on Vimeo with me checking 5 times over.
~Dylan
Re:Z arm not moving ? Help... anyone here?
Posted: Tue Apr 07, 2015 1:45 am
by cerriousdesign
I put it on Com 5 instead of com 4 and now the projector is displaying the correct output and I am getting a completion update in creation workshop but the z-arm is not moving??? I do not have the same looking output in device manager as in the vimeo video like on the little rp site. Here is a picture of my device manager window. Can anyone help please??? Do I need a driver for the arduino??
Re: Z arm not moving?? Help... anyone here?
Posted: Tue Apr 07, 2015 10:37 am
by Scatterplot
Yeah, you'll need USB-serial drivers. Try downloading the Arduino IDE.
Posted: Tue Apr 07, 2015 5:25 pm
by cerriousdesign
Which Arduino drivers do I use, I installed the IDE but that did nothing.
Posted: Tue Apr 07, 2015 5:49 pm
by cerriousdesign
I needed to install the drivers from http://www.ftdichip.com/Drivers/VCP.htm .. as soon as I did that and plugged in the Little RP it was recognized on USB Serial Port (COM 6). The Z Arm is now moving and ready to print. Oh yea.. make sure you turn off UAC in windows 7 otherwise it won't let you install the drivers.
Re: (Solved) Z arm not moving?? Help... anyone here?
Posted: Tue Apr 07, 2015 6:34 pm
by Scatterplot
Glad you got it working- the manufacturer drivers were gonna be my next suggestion :)
Posted: Tue Apr 07, 2015 6:53 pm
by cerriousdesign
Thanks for sending me in the right direction. :)
Posted: Wed Apr 08, 2015 11:58 am
by Dark Engineering
Just wanted to add that this fix worked for me as well last night.
