Z-Level
Posted: Wed Feb 18, 2015 6:42 am
by fraggle68
Hi guis,
after calibration my XY achses now I have a few problems with the z-level. I built an calibrationtool who is 10x10x4 mm. After printing erverytime it is 3,7 mm high not 4 mm. Wehre can I change the settings for the Z-level. In CW I changed the Z-level once 90 / twice 110 but nothing really happened.
Do you have an advice for me....
Re: Z-Level
Posted: Wed Feb 18, 2015 8:23 am
by ps_bond
Are you printing directly onto the build plate or are you using a platform + supports?
If the former, you'll probably find the same as I did with my cal block - the early burn-in layers aren't accurate in the Z axis, presumably due to a combination of exposure and the build plate compressing the PDMS layer (so initially, there's almost no resin under it).
Re: Z-Level
Posted: Wed Feb 18, 2015 12:22 pm
by fraggle68
I printed directly onto the built plate without a Plattform.
Re: Z-Level
Posted: Wed Feb 18, 2015 12:42 pm
by ps_bond
As has been pointed out elsewhere, the Z axis is pretty well defined by the screw pitch * amount of rotation - if your stepper motor isn't slipping, then the Z arm is being moved the appropriate amount.
