Build Your Own SLA/SLS • How to implement limit on the Arduino Mega 2560 and Cw
Posted: Sat Aug 29, 2015 5:13 pm
by dalaura10
Hello everyone
Does anyone happen to know how do I for a limit on the Z axis of a DLP printer that works with the CW , and Marlim , ramps . ?
I thank you for the attention
Re: How to implement limit on the Arduino Mega 2560 and Cw
Posted: Sat Aug 29, 2015 6:52 pm
by sodium
this is my working marlin firmware, with upper and lower limits. the upper is for security reasons, but not really needed. check all endstop settings and comments . its easy to understand. Also check #define X_MAX_POS 205 ( change value to your z axis travel ).
Posted: Fri Sep 18, 2015 2:06 pm
by dalaura10
Hi, tahnks for your help. I had a problem working with your code.
Look at:
Arduino: 1.6.4 (Windows 7), Placa:"Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
SdFatUtil.cpp.o: In function `SdFatUtil::FreeRam()':
C:\Users\Windows\AppData\Local\Temp\build8906941252038550266.tmp/SdFatUtil.cpp:33: undefined reference to `SdFatUtil::__brkval'
C:\Users\Windows\AppData\Local\Temp\build8906941252038550266.tmp/SdFatUtil.cpp:36: undefined reference to `SdFatUtil::__bss_end'
collect2.exe: error: ld returned 1 exit status
Erro compilando.
Este relatório deveria ter mais informações
"Mostrar saída verbosa durante a compilação"
habilitado em Arquivo > Preferências.
The sentences are in Portuguese but it does not matter.
Can you help me with this?
thanks
Posted: Fri Sep 18, 2015 6:45 pm
by sodium
just tried in arduino ide 1.0.6 and compile fine, but not in 1.6.5. two choices:
- compile and upload with the old arduino ide, or
- try to update the libraries yourself.
im not a programmer guru, so try the first option.
Posted: Sat Sep 19, 2015 7:15 pm
by dalaura10
sodio
Thank you for your prompt reply
I uploaded with Arduino and now 1.0.5 installed .
My question is :
which pin to use for the end of course , want to take the construction platform for home? If use the pin 18 and returns to the platform a few millimeters , this can not happen because then the construction of the platform is not in the exact house.
Posted: Sun Sep 20, 2015 11:11 am
by sodium
you want to use two limit switches? or only the lower one ? i dont understand your question very well ...
really, only one limit switch is needed to operate the printer, the one used to home the machine( Z0 ). i use another one at the other end of the axis for security purposes, but not really needed.
if use a ramps 1.4 shield, you can have two end stop or limit switches per axis.
Posted: Mon Sep 21, 2015 6:48 pm
by dalaura10
I'm sorry about my English. Some times I can not write in English as i think in Portuguese.
When i use pin 18 (minimum Z) my plataform goes down, find the dispositive wich closes the pin 18 and GND, and then goes up a few milimeters. I want it to stay exactly where is the travel end without goes back. My aplication here uses a travel end to start printing. I have a dispositive that "closes" the pin 18 when my platform goes to the start printing position.
I do not want it to gooes back after find zero position, i want it to stay there and then i will start printing from there.
I do no know if i am using the correct pin, or something else. But my aplication here is not as i want.
Posted: Tue Sep 22, 2015 11:04 am
by sodium
I dont know if cw directly or marlin firmware do that.
When i hit home buttom, the plataform goes down until hit the end stop. Then, goes back a few milimeters, but quickly goes down again to the end stop posición. At this point , z is 0 and you can start print.
If i understand you, your plataform goes down, hit the end stop, goes up a few mm and stop.
Try enter M114 at command líne and see where z is .
