Build Your Own SLA/SLS • Printer and Projector are out of Sync, help please SOS
Posted: Sun Mar 01, 2015 8:09 pm
by cwmain
I got my machine built and and moving, and I thought the firmware was done too, but
My printer does not move in the order of flash, ascend, descend, flash, repeat like this one here
My printer's Z-axis movements and projector's flashes are out of sync and get more out of sync as the print goes on. It flashes the resin before the plate goes back down. Here's my printer doing a dry run test:
Here's my "usual" CW settings:
The firmware on my GRBL is from here
Not sure what other info anybody would need, but I would appreciate any help :)
Thank you!
Re: Printer and Projector are out of Sync, help please SOS
Posted: Mon Mar 02, 2015 2:05 am
by Matze
My first guess would be that your lift sequence does take a lot longer than 2000ms. Try a higher value.Did you use the auto-calc button? If that's the case you should check your firmware stettings. Don't know much about grbl, but there should be a setting for max z speed. Hope that helps...
Posted: Mon Mar 02, 2015 1:11 pm
by cwmain
