z axis calibration
- Joined: Wed Oct 08, 2014 7:47 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
z axis calibration
Hi Steve, My first print turned out just great using your software. I've run into a bit of a problem on the z axis calibration. I've attached some pictures. There seems to be a drift as the z axis distance increases, is there a way to do fine adjustments? or is this a firmware problem? I'm using the Uncia
- Attachments
- Archive.zip
- (900.55 KiB) Downloaded 652 times
Re: z axis calibration
Can you determine how much it's off by?
Start at a position, and move the z axis 100mm using the software. Measure it and let me know how much it's off by.
off by 3mm for 100 mm travel
I did an accurate measurement today 102.8 mm
Brandon Pomeroy picked up my thread on this issue and did a mod on CW .I get 99.60
attaching his file
attaching his file
- PomeroyB
dangre, the problem was that CWS approximates the Uncia's steps per mm to be 90, when the actual value is closer to 87. I posted a recompiled version of CWS that had the correct value on the Uncia Google Group.
