Build Your Own SLA/SLS • my DLP build - Page 2
Page 2 of 3
Re: my DLP build
Posted: Mon Jun 23, 2014 1:58 am
by hp_
Yesterday i tried to print Ironman.
here is the result:
looks like the top part i did to fast a good learning lesson :)
the mask part came out really awsome!
Re: my DLP build
Posted: Tue Jun 24, 2014 1:30 am
by hp_
and here is the completed print.
~60 micron xy
100 micron in z
z speed: 200
exposure: 1900ms
first 5 layers: 6000ms
print duration: 1:39
resin: makerjuice subg+ mixed with subflex
Re: my DLP build
Posted: Fri Jul 25, 2014 4:41 am
by snow
hi hp_,
nice job!
got a few question about the resolution
for the ear you used 24 micron xy resolution. is that the maximum resolution for p1500 / closest you can get a sharp image?
if this unmodified projector?
thanks!
Re: my DLP build
Posted: Fri Jul 25, 2014 5:23 am
by hp_
Hi snow, this is all done with an unmodified projector. the aproaximate xy resolution is based on 1920 x 1080 resolution on 192 mm x 108mm = 100 micron - if you project on an area of 48mmx 27mm you would have ~25 micron per xy area.
i think this is probably the maximum resolution.
Re: my DLP build
Posted: Sat Jul 26, 2014 10:51 am
by EdgE
Very nice print! :)
What is the average printed wall thickness of the mask?
Re: my DLP build
Posted: Sat Jul 26, 2014 4:32 pm
by hp_
Hi Edge,
i've measured 1.5mm so i guess average.. 1.5 - 2mm
Re: my DLP build
Posted: Thu Aug 21, 2014 9:50 pm
by MichaelD33
Hey,
How are you peeling the print? It looks like your using a pillow vat, could you explain it a bit? It seems quite complicated...
Michael
Re: my DLP build
Posted: Fri Aug 29, 2014 1:01 pm
by anthony.julu
This is a wonderful work. The Ironman head looks great!
Hp, do you think that belt driven Z axis can do 25 and 50 micron layer thickness!
If it can do so, I would say it will be a great option to consider, since it's faster and quieter than a lead screw. Have you done any experimentation with those thicknesses?
Re: my DLP build
Posted: Fri Aug 29, 2014 1:17 pm
by hp_
i can confirm 50micron is also not a problem. i print this thickness all the time now.
25 micron i also tried and it printed but i made a mistake and let my vat run dry :)
be-aware i use a special VAT construction that makes this possible.. very low pull force needed :)
Re: my DLP build
Posted: Thu Jan 01, 2015 11:17 am
by hp_
Note to self, tension of the fep film is very important when using a pillow vat.
been struggling this morning and decided to check tension of the fep.. saw it was not stretched enough. fixed the problem.. and again.. printing with no issue :)
the more strechted and tensed the fep film is the easier it is to print with it.
