Hi!!! Recently I try to modifie a marlin firmware to add a serial port.
With this aditional serial port, I want to control a projector(Benq Mx522) that has a RS232 port.
Last year i use a B9Creator Printer and I liked the idea to control the projector via Arduino.
I could not do it. When i tried to modifie the files(MarlinSerial) I could not compile.
Someone interested in this???
Last firmware that i used was this:
Modify Marlin Firmware to control a projector like B9Creator does
- Joined: Tue Oct 28, 2014 7:34 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
- Joined: Thu Sep 03, 2015 10:38 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Modify Marlin Firmware to control a projector like B9Creator does
Hello Ramirock
I bought the projector Benq me know MX522P must disarm and remove some filters or works as manufactured or any partner of this forum have the projector working on your printer
thank you
thank you
Just FYI: CW can already control projectors through the serial port.
