creation workshop can control SLS 3D printer or not??
- Joined: Thu May 28, 2015 5:48 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I´m working in a company and designing a SLS 3D printer of prototyping. About the software to control the printer. I don´t know if Creation Workshop can do that or not? If yes, how? I mean the problem is to control the movement of a roller and the power of laser. On the site of Creation Workshop, it points out SLS controllers under development. Thank you very much!!!
Re: creation workshop can control SLS 3D printer or not??
We currently support the LaserShark board, and are implementing the e1701 controller as well. Several individuals have had success in using galvo systems to perform prints with both SLA and SLS. What kind of system are you setting up?
Yes, but it does require some customization. What are you using as the motor controller? A ramps board?
