Hello Guys
Hope you all are doing very good and your projects are going great
i have the Sedgwick 3D DLP Printer and i am trying to use it with creation workshop , when i connect the printer ,i only get projector control and not the motor movement
Sedgwick uses teensy 2.0 board
any help would be very appreciated
thanks
Re: Sedgwick 3D DLP Printer
Hi ay3ds,
You should be able to control the Sedgwick 3D printer using the Uncia driver for CWS.
Check out for the correct download:
You can also follow for connecting and setting up your Sedgwick. (They are technically for the Uncia, but the Uncia is an exact clone of the Sedgwick, so they should work for you as well.)
Hello,
I'm so glad to find someone else using Sedgwick printer. I wanted to upgrade from my printrbot to resin printing and this seemed to be the best value. The build wasn't too bad but the software keeps crashing on me. Using creation workshop Uncia version I got it working by just changing port speed to 9600 like was suggested in another thread. Thank you so much for making this program.
Ay3ds, send me a message if you want to talk Sedgwick
Ben
Ben
Ben
Still tweaking my Sedgwick
Does anyone know how to make a servo move in the G code before printing starts. The sedgwick has a servo connected to a piece of wood to cover the lens before and after printing.
Ben
Ben
Ben
Thanks for the quick reply. I tried adding the code from your images, but nothing seems to happen. If you have a chance would you mind checking the code for that M800 on the uncia version.
It's very frustrating being a total newbie.
Again thank you for making this program, it's great.
Ben
- Joined: Sun Nov 02, 2014 11:02 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
hmm so the sedgwick is setup only to do 100 microns
i wud like it to do 50 and 25 mic too , do you think this is possible ?
thanks
thanks
