CW Bug - Lifts before Exposure ends
Anyone else running into issues where the lift sequence starts before the end of an exposure?
Re: CW Bug - Lifts before Exposure ends
I'm looking into it. You can insert a short delay of 250-500 ms after the exposure before the lift to compensate for it. Should be fixed next version.
- Joined: Wed Apr 23, 2014 10:47 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Look here
is there any advantage in letting the layer "sit" for a couple of ms after exposure just befor before lift? Or is it ok to start the lift right after exposure is finished?
Cheers!
Cheers!
I had this happen to me as well. Restarting CW fixed it tho.
Research Chemist
Could it be an issue with showing slices in 3D while printing large polycount models? I can't prove it but my gut says it seems to contribute.
- Joined: Thu Jul 31, 2014 10:39 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I solve it with 8 M400, this command forces marlin to finish all command, and then Marlin can start with other command.. You must use 8 command to fill the buffer !
Research Chemist
