Page 5 of 6
Re: Creation Workshop RC9 - Not on GitHub!
Posted: Fri Aug 01, 2014 11:37 am
Version 21 is available through here:
Posted: Fri Aug 01, 2014 1:29 pm
by sgraber
Awesome! Does this release include fixes for the image display delay problems some of us have seen?
Shane
Posted: Fri Aug 01, 2014 2:20 pm
by Finhead
Posted: Fri Aug 01, 2014 2:55 pm
If you're feeling REALLY bold, try version 28, now with the image delay fix, additional slicing ink/resin parameters, and a few other nice fixes. Now, mind you, this version was a test version I had originally made for Uncia support (still only kinda working), but the rest of the build still works as normal. (although you may have to create new machine /slicing profiles)
It also has an experimental 'Exposure Tester' built in to help users determine the proper exposure of models by exposing different portions of the model with different exposure times.
Posted: Fri Aug 01, 2014 3:15 pm
by Glacian22
That exposure testing mode sounds interesting, I'll have to play around with v28, thanks!
Posted: Fri Aug 01, 2014 3:25 pm
by sgraber
Yes, definitely THANK YOU!
Posted: Sun Aug 03, 2014 12:46 am
by sgraber
UPDATE: I can verify this does take care of the image delay issue I've had. I would expect it'll work just as well for the others that saw this problem!
Posted: Tue Aug 05, 2014 11:44 am
by Batuta
Just wondering about diferent thickness in the same model.
Posted: Wed Aug 27, 2014 9:31 am
by sgraber
Posted: Tue Oct 14, 2014 9:07 pm
by MrBaz
Maybe I'm missing something that is right out in the open, but how do I generate supports? I have an older beta 13 version that generates supports, but the newer ones I've downloaded don't have the option of generating supports. Am I missing something?
EDIT: Nevermind, I'm an idiot. I just needed to click on the "+" button.
