I am trying to make my first print and have had 3 failures. In all 3 cases I get a blob of plastic on my platform (DropLit bottom-up printer, G+ resin, calibrated). My build platform (a small 2.5cm diameter) is not on center. The projector is fixed and can't be moved left to right I can center Y by moving the platform forward/back. I've tried using the Move commands in the slice screens but they don't seem to have an effect.
I think I have my focus calibrated, I place a sheet of paper over the hole in the base and project the image onto it and focus until it is crisp.
I've tried to use reasonable slicing parameters (or so I thought!) for the G+ resin:
3 first layers at 5000ms
layers at 1000ms
.1mm thick layers
10600ms lift and sequencing from autocalc.
I set my Z=0 with a thin trip of paper between the PMS and the build plate. The resin does stick to the Al build plate so that seems ok (although I am sure since it is not centered it is hanging off the side a bit).
I am trying to print a too complex for a first print Rhomball. I will try to find something simpler to print until I have things dialed in.
Trying to get first print...
- Joined: Sun Feb 15, 2015 9:27 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Trying to get first print...
Forgot the most important part - I'm using an Acer P1283 projector with the UV filter and color wheel removed.
I also figured out how to use X-Y move in the slice window so I am not able to center my object on the build platform. I was also trying to print the original ball pretty small, maybe 1.5cm diameter and had included support. I see now (after scaling it up 3x) that it has support as part of the model. So that might make things a little better.
Now I need to get a handle on the exposure/time parameters although it seems the resin was indeed curing and sticking to the platform.
Michael
Michael
try more cure time, maybe 3000-6000 ms?
