What is the easiest way to remove the the cover over the bulb so I can Replace it. I would rather not Rip it off and damage it.
Acer X152h question
Re: Acer X152h question
The clear plastic, or the main black bulb cover?
- Joined: Tue Feb 28, 2017 9:51 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
The black bulb cover.
make sure you remove the screw first..
https://www.manualslib.com/manual/94983 ... ml?page=38
