settings for B9 resins?
- Joined: Mon Feb 02, 2015 2:19 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
anyone having any luck defaulting settings with thier resins?
Re: settings for B9 resins?
There is a function in CW to calibrate resin, I think ideal exposure times depends on various factors, so the best way is to make a calibration. Unfortunately I cannot help you at the moment on how to use the function in CW. (viewtopic.php?f=5&t=2568&p=7638&hilit=calibrate+resin#p7638).
Meanwhile I use the calibration stls on the littlerp website, to adjust curing time.
Thanks! that should be enough to get me started on fine tuning,i been using to long i think because its setting up on the bottom of the dish
can't really find anything on how to do it?
- Joined: Sun Feb 09, 2014 4:42 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
From what I have heard the b9 resins react a lot slower. You will likely need layer times in the 20+ second range. But I haven't tested it to know for sure.
I find at 10+ it sticks to the bottom of the dish
getting great results with 23 base 22 expos
but looking like a 50% chance it sticks to the bottom lol
