Hi!
Seemingly there exists some kind of fluid to glue ("vernetzten") Silcone gel coatings better to glass and plastic:
[sorry, only german link]
http://www.silikonfabrik.de/product_inf ... 20-ml.html
"Oberflächengrundierung für Metall, Glas, Keramik und viele Kunststoffe. Diese Grundierung macht es möglich, eine Verbindung mit SF-Silikonen und den genannten Oberflächen herzustellen, die beim Vernetzen entsteht. "
translation:
Surface primer for metal, glass, ceramics, and many plastics. It enables a Connection between *Silicone gel* and this surfaces, which develop during "polymerisation".
Has anyone ever tried something like that?
greetings,
b
Sufrace primer for silicone/slyguard
Re: Sufrace primer for silicone/slyguard
i don't know if that is such a good idea. The coating is tough enough so that it doesn't peel off while printing, but it's easy to remove when changing coatings.
With the primer it should be pretty hard to peel off the existing coat.
It might be good to use for flexible silicone walls for a flexible VAT though.
