Drago,
I hope they can make it clear (transparent) then it is very promising. Frosted bottom may be good for low resolution prints but for high resolution prints its got to be clear.
My new material for VAT
- Joined: Wed Jan 07, 2015 8:00 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: My new material for VAT
some news from bulgaria?
Half casting-form is fully ready . Today I expect the other half and now must be polished. Maybe one or two weeks and will be ready for operation. It turned out that the casting-form is unexpectedly complicated and I made a mistake in the project of the casting-form which slowed me down.
Regards
Drago
Regards
Drago
Tomorrow the first sheets with 2 different hardness should be produced . Cross your fingers.
The sheets are ready but have some optical distortion. Will look for the cause.
we are expectant!!!!
- Joined: Mon Jan 05, 2015 5:32 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Any news? Really looking forward to this, have my printer together but am having trouble building a decent vat.
I found the cause of the problem-distortion 1.5-3 microns. Will be repaired. There was a problem with the vacuum on the glass but was solved successfully. However the problem, now it works much better than before. Now I have more free time and I will work mainly on this.
Regards
Drago
PS I found that the best results are when working with semi flexible bottom. Can be used directly on the glass or plexiglass or on ready flexible bottom.
Regards
Drago
do you think it has better anti-stick properties than fep? if being produced in flex state, it could be tensioned like fep?
I tried by MUVE3D FEP but I don't like it. This material work much better . I have not experience with other manufacturers of Teflon.
Regards
Drago
Regards
Drago
