Vivitek for B9 cherry
pouryatorabi
Postby pouryatorabi » Tue Jul 21, 2015 8:07 am
Hi everyone
I've made my own machine and bought some B9 cherry resin to test. Everything was alright and calibrated but I was really shocked that my projector couldn't cure the B9 cherry. I tested other kind of materials like EC500 from envisiontec. They are alright and I can work with them but not with B9 cherry. My projector is Vivitek D555.
Can anyone help me? what is wrong with my projector?
sgraber
Re: Vivitek for B9 cherry
Postby sgraber » Tue Jul 21, 2015 11:33 am
How far away is your projector from the resin? How well did the EC500 cure at that distance?
Research Chemist
pouryatorabi
Postby pouryatorabi » Tue Jul 21, 2015 1:57 pm
I'm using 100 micron. I'm well aware of printing process and I get good results with other resins but amazingly my projector won't cure just B9 Cherry. I think the problem is about uv filters. Am I right?
sgraber
Postby sgraber » Tue Jul 21, 2015 2:10 pm
It's possible. How long are you exposing the B9 to your light source? How far away is the projector from the vat?
Research Chemist
pouryatorabi
Postby pouryatorabi » Tue Jul 21, 2015 2:19 pm
I did the exposure for around 40 seconds to test. I told you I made the projector 100 microns and the distance is less than 30 cm.
sgraber
Postby sgraber » Tue Jul 21, 2015 2:30 pm
Research Chemist
pouryatorabi
Postby pouryatorabi » Tue Jul 21, 2015 3:04 pm
I think the D555 lumens is 3500. I also tried different kind of vivitek even a 1080p vivitek projector. But I had no success. The B9 itself uses vivitek projectors.
Sorry I didn't understand your question.
jwlrymkr
Postby jwlrymkr » Tue Jul 21, 2015 4:04 pm
Remove the UV filter from the lamp.
mongerdesigns
Postby mongerdesigns » Tue Jul 21, 2015 5:02 pm
With the b9 cherry you are going to need to remove the UV filter from the projector bulb.
pouryatorabi
Postby pouryatorabi » Wed Jul 22, 2015 12:51 am
Once I removed the uv filter from a vivitek projector and the projector burned. I'm a little worried to do this again.
