Hi all,
just registered so im very to the forum. this is my first post.
though i've built a couple of 3d printers, this is my first array into sla. just been reading on this this morning.
so to ask my first question, what are the specs i need to look into in buying a projector for an sla 3Dprinter? i know there is a list of projectors in another thread but those might not be readily available to me. that's where the specs come in.
is this enough? http://www.aliexpress.com/item/Mini-Led ... 4.html?s=p
id like to built it compact.
thanks in advance. hope to learn a lot from you guys and give back at the same time.
warm regards.
ferdz
Need Projector Info
Re: Need Projector Info
You're going to need a DLP projector. An LCD projector won't work. You should be able to ebay for a fairly cheap DLP.
Others recommend Acer H6510BD, so I placed an order on it yesterday.
It's good because
- Close focus range (down to 50 microns)
- High Lumens
- Compact design
- High Resolution
- Price
This would be my recommendation since you don't need to modify anything.
It's good because
- High Lumens
- Compact design
- High Resolution
- Price
- Joined: Tue Sep 30, 2014 1:47 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
thanks guys!
