Build guides / Plans
boelle
Postby boelle » Tue Dec 27, 2016 11:32 am
Hi
I have been using FDM for quite a few years now and are thinking about SLA
From what i have read laser is worse than DLP when it comes to print quality so i was thinking of going for that
I have also read that you can strip an old monitor down to the bare LCD panel itself... ie rip out all the difuser sheets etc until you have the glass panel with the flex cables on that you can see through with the naked eye
take that panel and put a BRIGHT uv lamp under it and use that setup as a bottom up setup. But is that any good compared to the DLP projector setup?
also i have yet to find a prober build guide for an printer. so far i have only seen "in progress" and done printers without any info
i was after something in the 200*300mm range... i know the output will always be what the projector is.. hence i aim a little bigger so i dont get under 200*200
are my thoughts possible?
boelle
Re: Build guides / Plans
Postby boelle » Wed Dec 28, 2016 7:04 am
so there are none ready to follow plans on how to build one ?
Postby hp_ » Wed Dec 28, 2016 1:26 pm
Hi Boelle,
its not only the output that matters its also the kind of resolution you want to get.
the bigger your print area, the rougher a print will be. with a projector you are always stuck with the number of pixels.
ybourini
Postby ybourini » Wed May 17, 2017 3:36 pm
check this
