Hello and have great time my friend,
I'm in the middle of building my LCD 3D printer and my plan was to use Retina 9.7" as my main LCD but seems that kind of LCD is not suitable for passing UV lights trough themselves!!!
So I need your helps, Could you حlease guide me about choose right LCD with reasonable price. I would like it be at least 8" - 10" and supporting 2K.
Waiting for your reply,
Help - Best LCD for UV printing (8" - 10")
- Joined: Sat Oct 07, 2017 10:37 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Help - Best LCD for UV printing (8" - 10")
Same here
. I want to build my own SLA LCD printer, but I'm not sure, if these "DIY projector kits" from Aliexpress are usable (like this one [1]). I'd like to build high quality printer for decent price. Are there any builders willing to help?
[1] - https://www.aliexpress.com/item/10-1-in ... 52369.html
- Joined: Sat Feb 11, 2017 6:18 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I think that screen would have to be taken apart and one of the polarizers removed for it to work with printing resin. I'm just not sure if it can be done easily. Some manufacturers glue everything together, others don't. at $80 it's almost worth a gamble.
I think we're on the cusp (finally!) of getting known-good UV-passing panels from China. Ideally I'd like to see 10 and 12 inch 4k displays.
. An iteration of earlier builds and 3d render only. Maybe it'll catch on...
And I just asked about 4k displays as well
. I'm actually making this printer for a school project. I'll also contact local university and ask the electronics department, if they know any good LCD panels that pass UV light, but I doubt so. Hopefully, I'll order it ASAP.
Good luck to you, man. I've examined my KLD-LCD1260 and it really is a simple device. I'd love to build one based on the same electronics but with this bigger screen, a better Z-stage(more rigid linear guides and w/ ball screw), vat tilt mechanism, and ~50W+ UV LED module. Be sure to document your project, as others will undoubtedly find it useful, even the little failures
