It's good points.
The machine looks good, the metal work is nice.
The interface looks nice and has some interesting features.
Big build volume.
Would make a good boat anchor.
It's bad points.
1. Machine needs modification before it can be assembled. (Get your grinder out and call Ilios for instructions)
If it was never assembled, then it was never tested as it was never assembled.
2. The Ilios Beam prints slower than continental drift.
By the time you printed anything the size of the print volume you would be old or dead.
It took 2 days to print a hollow 2cm cube with a 1mm wall. (Using the settings recommended by Ilios)
Part of the problem is the firmware which tells you that it will take an hour or two, but then it takes days.
3. Prints often delaminate from the plate and you can't find out for days because the printer is so slow. There is no way in the firmware to pause the print and raise the bed, then resume the print. The print is completely hidden by metal. There is a camera built into the machine, but it does not show you the print ...... All it shows is a white dot on a black background. This shows the laser moving, but gives no indication of the status of the print. Useless gimmick.
4. There is no air filtration on the unit, so your workshop will stink of resin.
5. The strongest feature of this printer is it's build volume, but you can't use it because the unit is so slow.
Ilios Service
It arrived months after the promised delivery date.
Ilios told me several times that it was shipping, but it was not the truth.
Ilios offered a refund because it is a useless piece of rubbish.
Ilios offered to me a refund IF I sent the printer back to them at my expense...... around $500.00.
They received the printer, inspected it, accepted it and promised to refund the money.
They have not made the refund and now have both my money and the printer.
They have kept me waiting almost 2 months and still have not honoured their promise!
Do yourself a favour and buy something else!
Ilios Beam is RUBBISH.
Ilios service is terrible.
OH ..... and now Ilios3D is for sale because they make rubbish. Where's my refund!
