I was looking for a resin printer that can print at XY resolution: 450 ppi (56 micron) resolution, (I want to be able to print a 20mm figurine and be able to see facial expression on it) so I came across the Miicraft+ these are the specs
Build Size: 43mm x 27mm x 180mm
XY resolution: 56 microns
Z-axis resolution: A. 5 microns as a step from 5~200 microns
B. 30/50/100 microns with MiiCraft Resin
Speed 3cm/hour @ 100microns/z axis 2cm/hour @ 50microns/z axis 1cm/hour @ 30microns/z axis
This also has a continuous resin refill system which I think is pretty cool and it’s a Pico DLP that’s the light source.
There was also a few others I was looking at like the Projet 1200 (which I feel is way overpriced, my opinion) and they have this “interesting cartridge system” for their resin (which is also overpriced), and im trying to figure out which of the two above ripped off the others design.
The Little RP (of course that’s how I found this forum) which I love, but for the fact that I have to get a DLP as opposed to it being built in. I was looking for something small and portable, and I love the idea of using pico dlp (there so cute, or maybe ill mod the littleRP with a pico dlp?
So my question for the community here is.
1) Has anyone had hands on experience with the MiiCraft or MiiCraft+?
2) Does anyone have suggestions on any other resin printers that come close to the 450 ppi resolution that’s priced under $2,500usd?
Thank you
I haven’t looked threw the forum so I don’t know if there is a review or thread on the Miicraft, but im looking.
